| Posted by Jim K on November 06, 19100 at 08:06:47: | |
| In response to Re: brass fixtures & stains | |
I believe I am refering to water spots: do ypu know a safe way to remove? : The fixtures come with an acrylic/epoxy coating to prevent stains. If the faucet is already staining, (i.e., discoloring not water spots), then the coating has been damaged or is defective. Once water and air can reach the brass plating, it is going to discolor and there is nothing you can do to prevent it. And as the brass discolors, it will cause more of the coating to disintegrate and then you get larger spots. :
| There are none. |
