Re: toilet flange/shower pan
Posted by John Bridge on November 05, 19100 at 13:48:22:
In response to Re: toilet flange/shower pan
I can help with the shower pan. If it's ceramic tile it is almost certain that the liner underneath is the problem. To test it, plug the drain with a small party balloon inflated slightly larger than the drain pipe (2 in.). Remove the hair strainer and push the balloon down two to three inches. Put a couple inches of water into the shower and stand back. Pop the balloon when you're finished.
Replies to this post
There are none.
