Re: No Dryer Heat
Posted by hj on November 04, 19100 at 23:07:07:
In response to Re: No Dryer Heat
If it is gas, then the repair may be more that the dryer is worth. If electric, it could be a timer or high limit failure, but it is usually a burned out element which is easily repaired.
: I don't know if you know anything about clothes dryers but I hope you do. The other day my dryer just stopped pumping out heat?
: Do I have to get a new dryer or is there a way I can fix it?
Replies to this post
There are none.
