Re: Floor safe
Posted by dick on November 04, 19100 at 22:19:04:
In response to Re: Floor safe
: Good point. I had not heard of post tensioned houses until recently. My experience with that has always been in commercial high rise buildings. It would appear that some housing has a special need that would justify the cost of post tensioning.
I think the special need is that the builder wants to make more money. Post tension is cheaper (less steel). It has been pretty much the standard around here (houston) for many years.
: : There could be another problem if you have a post-tension slab. You had better first locate the cables that run through the slab and make sure you don't cut or damage one. This can be done by x-ray, or you may be able to find the cable anchors around the perimeter "beam" of the slab. The cables run through the slab at right angles to the beam. The tension plates (anchors) are usually patched over with some sort of material that can be distinguished from the original concrete.
: : John
Replies to this post
There are none.
