| Posted by hj on November 03, 19100 at 08:26:28: | |
| In response to Re: Gerber Toilet | |
Now do the simple thing and pull the little tube that goes into the center pipe up until it is just inside the large pipe and secure it there. : Please advise what I can try next. : Our Gerber Toilet is leaking somewhere. Not outside the toilet but down the drain. I have replaced the gasket between tank and bowl, replaced the ballcock, and replaced the full drain and flapper and it still leaks. After the tank fills up it slowly leaks out and the water turns on to fill. This is happening about every 10-15 minutes. Help ... Thanks : Henry
| There are none. |
