| Posted by Neal Perkins on November 01, 19100 at 16:20:22: | |
| In response to Re: shower pan | |
The pan liner should go under the cement backerboard! You also may want to look into using DensSheild backerboard instead of the cement backerboard. It not only is lighter and easier to work with but it also eliminates the need for a vapor barrier (felt paper in your case). The paper front on the DensSheild bakerboard is waterproof, so neither water nor mositure have the chance to reach back behind the backerboard! |
