| Posted by Helper on November 01, 19100 at 10:20:39: | |
| In response to Re: need to remodel bathroom | |
: Need info in how to remodel bathroom. Mayor problems with the angle of cealing, water from the shower hits the cealing making paint peel. Curtain rod does not cover complete bathtub runs in to the angle of the cealing. One of the reasons you might have peeling paint is that the paint used contains an ancrylic which will not allow the moisture to escape through the ceiling. I would replace ceiling with new drywall and use a flat latex "ceiling paint" which allows moisture to go through the paint rather than standing on the surface causing peeling.
