| Posted by Paul Sampara on October 31, 19100 at 09:27:32: | |
| In response to Re: Another Sewer Gas Problem / Sump Pit | |
I'd be interested in hearing how you make out with your problem. I recently moved into a house and found that the previous owners have the laundry tub draning into the sump pit and there's always a smell in the area since there's always water in the sump pit. I'm having a plumber come over this weekend to look at the situation and offer some suggestions - probably to run the sink drain into the sewer line rather than the sump pit - maybe that will be a solution (albeit expensive - since you'll probably have to break up the floor to run the drain pipe to the sewer. Keep me posted Paul Sampara |
| There are none. |
