| Posted by hj on October 29, 19100 at 23:24:47: | |
| In response to Re: Gas Line for pool Heater | |
It is yellow polyethylene pipe. The fittings are either fused or special compression sleeved. You need special risers at each end of the pipe. It is a case of there not being a lot of difference in cost between a short pipe and a long one. I do not know the labor costs in your area, but around here, assuming the ground is not rocky or difficult digging, it would normally run about $600.00. : I am trying to get a gas line from the meter to a pool heater. The run is about 15 feet.
| There are none. |
