Re: Toto toilet - refill mechanism instructions
Posted by Terry Love on October 29, 19100 at 13:40:09:
In response to Re: Toto toilet - refill mechanism instructions
 Gary, On any toilet, the first thing to check would be the flapper. Does the flapper hold water. Adding food dye to the tank will help determine that. If the flapper assembly is leaking, then sometimes I have found that by loosening the screws allows me to examine whether there is a good seal, at either the flat rubber washer, or in some cases, the seal problem with where the overflow attached to the tank. When you are sure that holds water, the next step is the fill valve. The low end Toto uses a fill valve with a rod and ball. These are easy to find. The high end Toto uses a Hunter fill valve. Most any hardware store carries these. The link below has instructions. Terry
Replies to this post
There are none. |
