NG 3/8" COPPER TO 1/2" IRON...NO FLOW
Posted by DONC on October 25, 19100 at 11:31:10:
...a copper line carrying NG at 2PSI couples to 1/2" black iron where it Ts...one 1/2" feed of 5" into a regulator and a furnace...the other 1/2" feed runs 5' and elbows to connect to a regulator feeding a stove top. The furnace works fine. The stove will not even get enough gas to light...unless the furnace is on...then all four burners will light immediately, but the fourth burner causes a sound which I am presuming is the regulator not getting enough guess for the fourth burner...when the furnace goes off, the burner flame drops to a minimum, but stay lit...I do not understand and will have to wait 2 weeks before anyone suggested by the gas company can make an appointment to do the work...Also, why would Whirlpool say that a 3/4" pipe needs to be run to the 3/8" pipe leading into the regulator at the stove top? This is very confusing :o/
