Re: Water Powered emergency backup sump pump
Posted by Pumpguy on October 23, 19100 at 23:03:33:
In response to Re: Water Powered emergency backup sump pump
Hey hc, I just went there using the link on this board. It works just fine! Better check your browser!
: If the link is indicative of the company, then you had better buy your pump quickly, since the link is out of business.
: : I have become acquainted with a company that makes automatic, water powered backup sump pumps for home and small commercial use. Their web site states that the residential model pumps at about 750 Gallons per Hour while the commercial model pumps at twice that capacity. Is there any other water powered unit that can match those numbers? I have already looked at several and have not been able to find a better unit.
Replies to this post
There are none.
