Re: Damaged wallboard behind tiles
Posted by Bud...Suncoast Plumbing Inc. on October 10, 1998 at 10:10:34:
In response to Re: Damaged wallboard behind tiles
David:---Do the job right the first time. Remove all the dammaged dry wall 12"-16" up from the pan lip....replace it with wonder board or similar material and retile with salvaged or similar acceptable colored tile. A patch job will probably cause additional problems with water leakage downstairs in the not to distant future, and then you will be faced with the problem again. Lots of luck...Bud
Replies to this post
There are none. |
