| Posted by Eli Burke on October 17, 19100 at 10:16:08: | |
This morning I was awakened by a high pitched keening from the basement. The cold water pipe on the water heater was vibrating. Turning on faucets changed the pitch, flushing the toilets made the noise stop while the tank filled. Finally I turned on the outside hose to stop the noise. I had an incredible amount of water pressure; I could shoot water 1.5 - 2 times farther than normal. I finally figured out from the water draining into the sump that it was the pressure release on the So my question is, do I have a faulty pressure regulator? Was this some sort of transient Thanks for any advice |
| There are none. |
