| Posted by John Scavnicky on October 17, 19100 at 08:41:07: | |
What is the correct procedure for handling a self caulk drain for a shower pan? Do you remove the rubber sealing gasket from the drain assembly prior to installing the shower pan in a bed of mortar mix or do you leave the sealing gasket in place? |
| There are none. |
