How old is the plumbing? Gages do wear out. I live in an old house and raising the water pressure could burst a pipe. First get an antiscald (parden my spelling). Replace any filters on system. Clean shower head. If that does not work then check with your well supply company before you try the following. On your limit switch you have a low pressure turn on (usually set to 25pounds and a high pressure cut off. If you turn the high pressure cut off switch to 45pounds on your gage (replace if more than two years old) that should help with your problem. (My pressure is set to 55psi) again check to see what is the recommended pressure for your region and piping system in your house.
