Re: Move a Shallow Well Pump
Posted by Bud..Suncoast Plumbing Inc. on October 09, 1998 at 19:13:01:
In response to Re: Move a Shallow Well Pump
bill:---You sound to me like your fit and able to relocate the well line to the pumps' new location. The most importent thing to remember is that these pipes will no longer be accessable once the concrete is poured. So take your time and be sure that there are no leaks in the system. As for repriming the pump when you are finished, fill the pump housing with water and let it run. a self priming centrifugal pump will be able to regain its' prime as long as you keep some water in the pump housing while the motor is running. Lots of luck...Bud.
Replies to this post
There are none. |
