Re: Toliet Flange
Posted by Gary on October 12, 19100 at 18:20:45:
In response to Re: Toliet Flange
: I have a cast iron flange which is leaded into the 4" cast iron wastepipe. The flange is not screwed or bolted to the floor and never was. I am rebulding the floor and should I screw it to the floor or just bolt the toliet onto the flange (flange is level to 1/2" above floor)?
Flange in designed to sit flush on finished floor and be secureled attached to subfloor, or toilet may wobble. If it's a 1/2inch above finished floor, you've got a problem.
Replies to this post
There are none.
