| Posted by hj on October 12, 19100 at 01:04:48: | |
| In response to Re: Galvanized Water Pipe Treatment | |
While the whole system is probably compromised, rust immediately after turning on a faucet often indicates that the pipe coming through the wall is extremely rusted, usually due to the brass valve being attached to it. : Our apartment block was built 1940 and has galvanized water supply pipes. Whilst water pressure is excellent, rusty water appears on first turning on the faucet. As the building is solid brick with hidden piping, replacement will be costly. Is there a high possibility of failure (Leaking)? Is some sort of chemical corrosion treatment possible to arrest the problem at least as a short term solution?
| There are none. |
