| Posted by Bud..Suncoast Plumbing on October 11, 19100 at 22:44:26: | |
| In response to Re: Dissassembling poured-lead sewer hub connection? | |
Frankied: Cut the PVC off close to the bell of the Cast Iron. Take an electric drill with a 1/4"- 5/16" bit and drill down into the lead caulking along side the PVC. With a little wiggle action you shouuld be able to eat a hole in the PVC and the lead simutaneously. You should do this at two point 180 degrees apart. Put a rag in the pipe so you don't lose the pieces and use a large screw driver to coax the PVC..Lead and old oakum from the Cast iron hub. You can connect your new PVC to the Cast Iron by using a Multi-tite type gasket in the hub, and simply pushing your new PVC into it(CHAMFER THE EDGES ON THE PVC FIRST) put a little soap on the PVC before pushing it home. Lots of Luck...Bud
all, : You might ask why not just cut the PVC pipe, and use : Thanks in advance for any help!
| There are none. |
