| Posted by Doug on October 10, 19100 at 23:39:34: | |
| In response to Re: Low water surface in toilet | |
: : I just replaced my toilet, and the water surface is just above the entrance of the trapway. I wanted to see if it was a tank problem or a bowl problem, so I tried to fill the bowl slowly with water. The more I poured, the more it emptied. I called Eljer and they said it was the wax ring. I used an extra thick gasket with a urethane foam core. Could that cause a problem? : does it flush properly? : how old was the old toilet? : most of the new toilets are low consumption toilets : if it does not leak then the wax ring may not be the problem.
