| Posted by hj on October 10, 19100 at 08:42:56: | |
| In response to Re: Low water surface in toilet | |
The water level is designed into the toilet. Whatever the level is when you pour water into the bowl slowly is where it will always be. Wax rings, adding more water, or anything else will not change it. : I just replaced my toilet, and the water surface is just above the entrance of the trapway. I wanted to see if it was a tank problem or a bowl problem, so I tried to fill the bowl slowly with water. The more I poured, the more it emptied. I called Eljer and they said it was the wax ring. I used an extra thick gasket with a urethane foam core. Could that cause a problem?
