Re: Pitch from home to tank
Posted by DMAC on October 09, 19100 at 21:20:12:
In response to Re: Pitch from home to tank
: Don't know if you received my other message....
: Well I have just put in a sewer line into and existing tank, And we put a 1/2 inch pitch on the 3" PVC, I read that it should be 1/4 inch pitch.. Will 1/2 inch be ok?? And is it better for it to flow faster or slower into the tank...?
: Thank you,
: Rick
the biggest problem you will have with too much fall is that the water could run off and leave the solids behind
but 1/2" per foot should not be that bad on a 3" line as long as it's not real far.
Replies to this post
There are none.
