| Posted by Doug on October 09, 19100 at 11:47:56: | |
I just replaced my toilet, and the water surface is just above the entrance of the trapway. I wanted to see if it was a tank problem or a bowl problem, so I tried to fill the bowl slowly with water. The more I poured, the more it emptied. I called Eljer and they said it was the wax ring. I used an extra thick gasket with a urethane foam core. Could that cause a problem? |
