| Posted by hj on October 06, 19100 at 00:42:05: | |
| In response to Re: Dishwasher | |
That loop is needed to keep the sink from backing up into the dishwasher if the drain gets plugged. But you do need a loop that is higher than the water level in the dishwasher to keep the water from leaking out during the wash cycle. : I just installed a new dishwasher. The location is not adjacent to the sink so it was not convenient to connect supply and drain to the sink connections. I ran the supply line through the floor to a hot water supply directly below in the cellar. I also ran the drain through the floor to the septic drain. I installed a trap just below the floor level between the washer and the septic drain. My question is this: The instructions say that when connecting the dishwasher drain to the sink drain a loop must be provided in the drain pipe that is about as high as the dishwasher. Why is a loop necessary? I obviously have no loop. Do I need a loop as high as the dishwasher even though I am not going into the sink drain? Thanks
| There are none. |
