Re: Pitch from home to tank
Posted by hj on October 03, 19100 at 00:30:59:
In response to Re: Pitch from home to tank
Studies over the past few years have found that the amount of pitch is immaterial as long as it is more than the minimum. After all, a vertical pipe has infinite pitch and they do not have problems.
: Don't know if you received my other message....
: Well I have just put in a sewer line into and existing tank, And we put a 1/2 inch pitch on the 3" PVC, I read that it should be 1/4 inch pitch.. Will 1/2 inch be ok?? And is it better for it to flow faster or slower into the tank...?
: Thank you,
: Rick
Replies to this post
There are none.
