Re: Electrical heat tape on water pipe in crawl space
Posted by More on October 02, 19100 at 23:53:27:
In response to Re: Electrical heat tape on water pipe in crawl space
: Any pros or cons on use of heat tape under crawl space? We had one put on which is thermostatically controlled, approximately 18 years ago. A friend told me he had his removed because of fire potential...tape gets old, cracks, gets damp, etc. I think mine has some insulations over the tape too. Does anyone have a comment on the safety of this? (PS - an electrician went under the crawl space last year at my request but said he couldn't tell the condition of the tape since it was covered with insulation.)
The pro of heat tape is the pipes not freezing. Your friend had his removed because it was so old and dangerous. Yours is covered and protected. If you're worried about it, remove some of the insulation and ask the electrician to re examine it.
Replies to this post
There are none.
