Pressure Tank Good? Bad?
Posted by Garrett on October 02, 19100 at 23:21:24:
My pump keeps turing on and off frequently and I noticed that the pressure tank drops off very fast after 50psi. I shut off the pump and drained the tank out of water and then checked the pressure in the tank. It was 50psi, so I let air out of the tank to 33 psi. (my switch cuts in at about 36psi) The next night the tank is doing the same thing? Does the blader have a hole in it or is it? I have been watering my lawn and it has been using the pump and tank quit heavily. Any Suggestions would be great! Thanks.
Replies to this post
There are none.
