Re: No hot water!
Posted by More on October 02, 19100 at 23:19:11:
In response to Re: No hot water!
: I went to my water heater and found that the hot water was running out the pressure relief valve.I shut the water off.Turned off the power.Drained some water out of the tank.Turned the water valve back on.When the water level reached the valve it still drained out. My question is,bad valve? Could it be something else too? Any help would be great.Thanks for your time. Steve
Suree sounds like a bad temperature pressure relief valve.
Replies to this post
There are none.
