I have just purchased a new Kohler Wellworth; I haven't installed it yet, but I have confidence that it will work great. I've read that Kohler has improved the trapway in the bowl, and I have seen that they have used a different flapper in the tank instead of the white plastic one used in the first low flow Wellworths. If it needs replacing, a conventional one can be used now. The foam float can also be adjusted for a better flush if necesssary. Which ever toilet you do decide to buy, I would recommend an elongated bowl for comfort. Don't assume that I'm saying that this is the best unit, there are way better toilets like Toto and Gerber, but this is the one that fits my budget, and I believe that it is way better than a Mansfield Alto.
