| Posted by Bud...Suncoast Plumbing on September 30, 19100 at 18:21:40: | |
| In response to Re: How High The Pipes? | |
Ed: Many normal installations, aren't normal or standard or regular anymore. Not lower than 15" on the waste arm or you'll have problems with a garbage disposer hook up and 20 or 21 inches on the water supply. Some times it pays to read the rough-in dimensions suggested by the manufacturer. Lots of luck...Bud. I need to now how high from the floor should the drain pipe and the water supply lines be for normal installation of a kitchen sink (the rough-in dimension)?
| There are none. |
