Re: plumbing
Posted by hj on September 29, 19100 at 23:27:16:
In response to Re: plumbing
After you get it apart, what are you going to do with it? The stoppage is not supposed to be in the trap or cabinet drain pipes so you will still need a drain snake. It is ofter cheaper to have a plumber come and use his than to rent one with all the headaches you could get into and then still need to hire a plumber if it doesn't work.
: Hi; Our kithen sink has been plugged for a couple weeks; I've tried "liquid plumber, foamy" several times well as plunging
: as well as plunging and this doesn't work, so it appears as if we have to take the black pipe apart under
: the sink. A fellow at "Revy" advised me to undo it with my hands but it looks like it is glued or something
: and not possible to loosen without tools. What do you advise?
Replies to this post
There are none.
