| Posted by Frank Garza on September 29, 19100 at 07:03:00: | |
Hi. I have a BRYANT model 340MAV high efficiency furnace that is 4 years old. Last year, the furnace would stop running due to a pressure switch fault. I have verified that the air flow is indeed ok. The problem seems to be the pressure switch itself - the switch or contact within the unit is intermittent. If I jiggle the wires and/or contact on the switch, the contacts close and the furnace will start back up. Obviously I need to replace the switch. However, i've been unable to find a source Respectfully, |
