Re: cutting cast iron pipe
Posted by peanut on September 28, 19100 at 21:26:52:
In response to Re: cutting cast iron pipe
: A hacksaw will take forever and if you use a sawzall, you will want to get 8 tooth metal cutting blades. The finer ones will just polish it as you found out. The easier option is a san soil pipe cutter.
: : Hi,
: : This is embarrassing. I need to cut a two inch castiron drain pipe. I have started cutting it with 24, 28, and 32 tooth per inch hack saw blades. While in an awkward position, I am not weak and have cut a good deal with this humble tool. So, what is the story on cast iron pipe. True, when I went to get some new 32 tooth blades, only ACE hardware was open, but right now the blades only scrape off the black paint. I have used Sawzalls at work for about everything, but, I cannot use my work tools for home huse. Any suggestions.
: : Cal
what the hell is a san soil pipe cutter
Replies to this post
