| Posted by Mark on September 26, 19100 at 19:02:41: | |
| In response to Re: Loop venting | |
: : Terry..if in the case of installing a basement toilet, i am too far from the horizontal soil line to tap into, do i need to run a loop vent?? and i assume the loop vent can be run into the main vertical vent..correct? i am about 5-6 feet from the soil line running out of my basement ..what would be the best way to install if not using a loop vent for proper flushing and to protect against siphoning? : : Thx again terry awesome site :) : : Mark : Mark, : If you are not connecting the vent back to the vent stack (not waste), you may want to look into a air emitter valve, that will break up the siphon affect. Studor makes one. Studor.Com : Regards, Terry awesome info..thx very much :)
| There are none. |
