| Posted by Michelle Dillon on September 26, 19100 at 13:28:57: | |
Can you tell me why the softener holding tank is over half full and not softening the water? Checked exit lines(clear), electronic display(Ok), has salt, sounds to be regenerating. Only problem I found was a destroyed gasket inthe nozzle/venturi assembly. (on order) thank you michelle |
| There are none. |
