| Posted by Terry Love on September 23, 19100 at 21:27:25: | |
| In response to Re: Loop venting | |
![]() : Terry..if in the case of installing a basement toilet, i am too far from the horizontal soil line to tap into, do i need to run a loop vent?? and i assume the loop vent can be run into the main vertical vent..correct? i am about 5-6 feet from the soil line running out of my basement ..what would be the best way to install if not using a loop vent for proper flushing and to protect against siphoning? Mark, If you are not connecting the vent back to the vent stack (not waste), you may want to look into a air emitter valve, that will break up the siphon affect. Studor makes one. Studor.Com Regards,
