Shallow well pump will not turn off
Posted by Kolin McIntire on September 23, 19100 at 17:32:42:
I have a 2 gallon pressure tank w/ diaphragm. It is charged to about 45 psi. I get good water pressure out of the hose. I have primed it using another water source (hooked up the hose to the pump discharge outlet and pressurized it. Does this fill the pump with water also?)
I have to unplug it to get it to turn off. Is there an easy way to check the pressure switch, the tank (to see if the diaphragm is broken) or any thing else that I am not thinking of?
Thanks in advance for your help...
Replies to this post
