| Posted by Akmed on September 21, 19100 at 06:53:34: | |
| In response to Re: dishwasher | |
Dominique: Could be the solenoid valve that allows water to enter the d/washer...the water level switch...the timer...or the water supply to the d/washer. You can test the valve by applying 110 volts to the coil connection...if it opens check the water level switch if it is working, it is the timer..door latch switch or connecting wiring. Lots of luck..Akmed
| There are none. |
