| Posted by hj on October 02, 1998 at 22:50:46: | |
| In response to Re: Shower valve | |
The only one I will use is the Delta Monitor 1500 series pressure balanced with a knob to preset or maintain the temperature and a lever to control the volume from zero to full flow. The units that have a single knob to do both will not always maintain the temperature from one time to the next since you have a tendency to move the knob while adjusting the flow. : I am looking for a simple shower valve for a kids' tub and shower. I want to be able to control temperature and volume from the same knob. What I've been finding are valves that give you temperature control but only full-on or full-off. I'd like to have the ability to run only a trickle from the tub faucet if desired. Can you help? : Second question: What are your favorite upper-end faucet lines for kitchen and bath? : Thanks!
| There are none. |
