| Posted by James on September 19, 19100 at 09:56:39: | |
| In response to Re: exhaust venting of gas dryers | |
: There is a room addition built behind the garage. The laundry roonm is now appox. 18 feet from an outside wall. How do I do a proper venting and what material do I use. Thanks : Use 4" sheetmetal ducting for your run or you will never get the lint, and/or other stuff out when you have to clean the ducting. The flex tube will work but it's a devil to clean out and with an 18' run, you WILL need to clean it on a regular basis. The dryer simply won't push the lint that far.
| There are none. |
