| Posted by hj on September 19, 19100 at 00:08:45: | |
| In response to Re: Flush handle for Wellworth toilet | |
Did you replace the flapper mechanism at the bottom? That will stick to the flush valve, after it is a certain age, and then will bend the lever mechanism before it start to flush. : : The flush handle assembly for my Kohler Wellworth toilet seems so springy that when the flush mechanism is pushed down, sometimes it needs to be held for a second or two before it flushes. : : Any suggestions
| There are none. |
