| Posted by hj on September 15, 19100 at 22:57:23: | |
| In response to Re: Sewer line repair - How would you proceed? | |
You are asking the impossible. We have no way of knowing the job conditions, what or how much was damaged, or any of the myriad other conditions that could occur. The one thing I will never do, and most good plumbers will not either, is second guess a job after it is completed. After the work is done, it could appear to be a very simple job, but while doing it, it could have been a very time consuming miserable job. : Scenario: : A plbg contractor is called out to a Condominum property and asked to fix a ruptured water main. : I need to compare your procedure with what was actually done. The condo suffered a large scale sewer back up shortly after : :
| There are none. |
