| Posted by hj on September 30, 1998 at 22:05:10: | |
| In response to Re: whirlpool tub installation | |
The location of the drain seldom refers to the occupancy load. If the tub is symetrical so it can be rotated to either side, then the drain will often be at one end. If it is assymetrical and has a definite front and back, then the drain will be in the center. The drain can be assembled any way that works to allow a tight connection, but the drain should be below the drain fitting to avoid odor buildup in a long pipe. : I am planning to install a whirlpool tub in an alcove : I want a tub with a center drain to permit use of the
| There are none. |
