| Posted by More on September 13, 19100 at 23:08:17: | |
| In response to Re: Boiler Pump - Flow Direction | |
: Normal practice would have the pump on the returns pumping to the boiler. Since the thermostatic valves would usually be on the pipe at the top of the boiler going to the radiators, I think you want your pump to pont to the boiler. : : Terry, Hot air and Hot water rises.The boiler has a closed loop system. It heats the water, which rises, and pumps that water from the top, past the thermostat which senses that the water is plenty hot and shuts off the boiler, or senses that that water isn't hot enough, and starts a fire under it, and then pumps that heated water to the radiators. When that heated water radiates its heat through the metal into the room, and cools, that water falls and returns to the boiler as a condensate (through the condensate return manifold [header] which is lower. |
| There are none. |
