| Posted by david on September 10, 19100 at 22:17:57: | |
| In response to Re: INSTALLING SHOWER PAN | |
: : I HAVE A SHOWER THAT IS NOT STANDARD SIZE AND THEREFORE I CAN NOT USE AN INSERT, I HAVE REDONE ALL OF THE WALL BOARD , BUT I AM NOW AT A STAND STILL I AM, NOT SURE HOW TO DO THE SHOWER PAN Go to the plumb.supply house.YOU WILL NEED A POLY-BUTYL LINER..Instaii the walls and the curb at the entrance.CUT THE LINER TO RUN UP THE SIDES AND OVER THE CURB. iT CAN BE STAPLED UP ON THE WALLS AND GLUED ELSEWHERE.wITH THE DRAIN IN PLACE AND THE CURB HIGH ENOUGH TO FALL TO IT,MIX AND INSTALL THE MUD BED FOR THE TILE.BE SHURE TO HOLD DOWN AROUND THE DRAIN THE DEBTH OF THE TILE,AND THAT IT IS THE LOWEST POINT.MUD IS A PREMIXED SAND MIX WITH PORTLAND CEMENT ADDED ON SITE.MIX THIS DAMP AND PAT IT DOWN VIGOROUSLY TO AVOID SHRINKAGE.GOOD LUCK |
| There are none. |
