Re: pressue switch
Posted by More on September 10, 19100 at 20:08:46:
In response to Re: pressue switch
: have a well, and the pressure switch operates in the 25 to 45 range...as the pressure drops the shower hot water gets too hot and the pipes begin to sing....how do I set the pressure switch...
: Thanks \
: DR Hedrick
There's a screw on the top of the pressure regulator that allows you to remove the cover. Inside you'll see two springs with adjustment screws on them for pressure relief. The larger spring if for stopping the supply fill. the smaller spring is for starting the supply fill
Replies to this post
There are none.
