Submersible Pump Leak a Problem?-Fireants
Posted by Kay on September 08, 19100 at 19:29:05:
In response to Submersible Pump Leak a Problem?-Fireants
I forgot to mention the fireants have caused problems before in the well house at the electical box between the tank & pump and also at the electrical connection on the tank. The tank sets on sand inside a shed, and I keep the floor covered with Diazon granules which have prevented them from causing this problem again along with using moth balls in the boxes away from the wiring. But outside where the pump is, I sometimes treat around the barrel, but wonder if they could have gotten in and messed anything up with the wiring there.
