| Posted by hj on September 06, 19100 at 08:57:42: | |
| In response to Re: air bubbles coming into toilet tank | |
You are getting what is known as aspiration. The inlet valve is not shutting off properly and is allowing a small amount of water to pass into the tank. In the process it is drawing air through the little refill tube causing the bubbles you see. Replace both fill valves and the problem will be solved. : Thanks in advance for any help on this. I live in a 30yr old house, which I assume has the original plumming fixtures based on the aged look of it all. After flushing either toilet, BOTH toilets will start gurgling at regular intervals: 3-4 quick bubbles, 5-6 seconds apart. This goes on in both tanks for about 15 - 20 minutes and then stops. The bubbles are coming from the fresh water supply leading into the tank. Shutting off the supply valve below the toilet stops the bubbles. My assumption is that if air is coming in, water is going out somewhere. Right? But I see no leaks in the garage below the bathrooms. Can anyone give me a clue? Thanks in advance. : Anthony
| There are none. |
