When replacing an old toilet, I noticed that the flange was raised a little on one side. When I bolted the new toilet to the floor, I could tighten it so far, and then when putting weight on it to see if it would hold, it broke loose. I re-applied the wax ring the best that I could on the bottom of the toilet, and think that I have it secured now. I didn't have a long enough fill supply line to try it out, but wanted to see if I should just have a plumber replace the flange and finish the job of replacing the toilet. Thanks!
